mobileineurope
My RT-AX88U on Merlin 384.16 (dirty upgrade from .15 - which was a clean install) gives us ping spikes up to a second - sometimes every 2-3 minutes. My son is a gamer - and is frustrated He is the only client on the 5 GHz net (channel bandwidth 80 MHz) - everything else is on 2.4 GHz.
It happens if we share some bandwidth with neighbours. If I select a clean DFS channel - we do not see the problem. If we could just stay there all would be fine, but the DFS channel detection sometimes (every 2-3 days) detects radar and switches to non-DFS.
What I am puzzled about is that the interference from the neighbours should be minimal. We live in a residential area with good distance to our neighbours. The strongest other 5 GHz net seen is at - 84 dBm, should this really be causing so large ping spikes every 2-3 minutes?
If I use another (non-DFS) channel with (low) interference it is the same pattern. Only a clean channel makes the problem go away.
Any suggestions?
Any suggestions?
