What is the file?
A binary or a script?
If script please post content here.
What exactly did you type to attempt to run it?
Being "armv7" does not guarantee that it will run on your router. It needs to be in a format supported by the router's kernel, needs to use the same endiness, etc...
The root filesystem is read only. You have to use /jffs or USB storage for persistence.
You can run a binary from anywhere, I’d presume this exe is just not compatible as Merlin suggests
