Lackooo
My question is why every 5GHz channels above 48 is removed from the final builds? I have problems if I using my router on these lower channels. I have a wireless headphones using 5GHz wireless, and there's some interference if I use the low (36-64) wifi channels. If I using higher channels via beta firmware (100-140) the problem is gone. Could you just put the higher channels to able to selected in the final builds please? Thanks.
