twennywonn
I recently purchased 2 Asus AC87s one set up as a router the other setup as and AP. I use 2 to get adequate 5GHz coverage and typically Im connected to the AP on 5GHz however it always locks up and the only fix is to power cycle. My question is, is this a known issue or do I have a bad unit. I was on the latest firmware and had the issue so I upgraded to the merlin firmware and the issue is still there. Should I do a reset and set it up from scratch? As far as I can tell the 5GHz on the main router has been fine.
Any help would be great, I had the WRT1900 and the Asus is more reliable when watching 1080p video on laptops where the I would get buffing issues with the Linksys.
