DancesWithLysol
I'm looking for troubleshooting advice.
Yesterday I upgraded from a RT-N66U to a RT-AC86U (BF sale). Since I do most of my networking using Ethernet, I was plenty happy with the N66U, but I was very interested in upgrading to a "supported" version of Merlin's firmware. I turn off the "fancy" features (e.g. QoS, Game Boost, USB storage, VPN, AiProtection), and just stick with typical settings.
I downloaded the settings from the old N66U, unpacked the new router & set it up. Once everything appeared to be working, I flashed to the latest stable Merlin firmware (384.7_2). The last step after the firmware upgrade was uploading settings from the N66U. All was well, so I went to bed.
When I woke up in the morning it appeared that the 5GHz radio wasn't working properly. All the Ethernet and 2.4GHz connected devices were having no trouble. I went into the admin pages and looked at the Wireless settings for 5GHz. There was something obviously wrong because some settings weren't adjustable (e.g. the select box for Control Channel was empty, and the text next to it said "Current Control Channel: 0"). Previously the 5GHz settings were all default/auto settings.
I rebooted the router, and all was well again.
A few hours ago (and ~10 hours after the last reboot) I noticed that the 5GHz SSID was unavailable again. I ended up rebooting the router to fix things again.
I'm curious if anyone else had this problem. Is re-using the settings across versions of Merlin a big "no-no"? I figure that if the settings are bad, then I'd see the problems right away rather than have it work for half a day and then go bad. Could it be a hardware issue? When Googling the issue I ran into a few cases of people complaining about 5GHz radio issues with this particular model of router (e.g. on Amazon).
Thanks in advance!
Thanks in advance!
