Hi All,
I went outside with my laptop, sat on the patio and tested every channel using inSSIDer to find the best channels and frequency for 2Ghz and 5Ghz. They use two different names and passwords keys. My 5Ghz blue LED never came on so I exchanged the unit, set up the new AC66U to the identical config.
Using my laptop, the 5GHZ (green line) signal strength goes up and down for seemingly no reason. Any idea why it would do this? I was not processing any data, no browsing, nothing. 2Ghz is stable, the light blue line. Should I retest this exchange unit...go back through every channel/frequencies to find the best ones again?
5Ghz setting: Channel 48, 40MHz (80 mW)
2Ghz setting: Channel 7l, 40MHz (125 mW)
