6ghz airmesh channels
crazymexican
Hi im having issues seeing and connecting to my airmesh nodes on 6ghz. My 6e devices can only connect to my main router asus GT-AXE11000. I suspect the zenwifi et8 nodes are not set to the correct channel. In my region only part of 6ghz band is accessible.
I've logged into my airmesh nodes with ssh. How do I view and edit the wifi settings for the 6ghz ssid?
Something like nvram wl2 channel 69?
I tested the Et8 routers in access point mode and I can only connect to them when set to channel 69. When set to auto my device don't see the 6ghz network. I suspect when set in airmesh mode they stay set to auto which is why I cannot connect to them. If I can set the channel manually I think it will work.
Set the wireless settings you want on the AiMesh router... those settings will propagate to all AiMesh nodes. AiMesh requires all nodes to use the same wireless settings... this is how wireless nodes interconnect... on the same channel.
OE
B Disable Specific WiFi channels - ASUS RT-AX88U ASUS Wi-Fi 8
