Do you use it at home?
I don't use IPv6 anywhere, home or business, multiple networks. I have public IPv4 addresses available, IPv6 not needed.
Perhaps I'm the outlier here for holding out for so long.
No. Used when needed, not used when not needed. If you have public IPv4 address on your WAN side you don't need it.
My ISP supports it but 1.5 month ago something broke on their side - all my configs got corrupted. They restored ipv4 but failed to fix ipv6 since. No matter how hard I attempted to help them debug the issue... It appears that GPON is not giving me any ipv6 address. Some kind of conflict or whatever. This is my sad ipv6 experience so far. And I already paid for cloudflare to take stuff from my server via ipv6 and translate into ipv4 for world access. Sad.
My ISP has still has a slow 6RD Tunnel in 2024. So you can enable it to get ~150mb IPv6.. So no, I have it disabled.
100 percent yes...
The only complaint I have is that my primary ISP only offers a /64 for a PD...
What I've found is that when running dual-stack, IPv6 is generally the first choice, then the fallback to IPv4 for hosts that are dual-stacked...
Keep in mind that even if one is not running IPv6 on the WAN, one is likely doing IPv6 internally via local-link...
My ISP (Telenet) started handing out IPv6 addresses and prefixes in 2010. When they did that, I also started to use it. Had very few issues since then. They offer a PD of /56 to their customers.
IPv6 WAN users: What is a "PD"? Are you using NAT, so that you consume only one WAN address, or does each client on your LAN have an external IPv6 address?
PD = Prefix Delegation. Think of it as a "global" IPv6 address that gets assigned to your router and from this prefix the router creates IPv6 address for all your attached clients (SLAAC or DHCPv6). I do not use NAT with IPv6. No real need to in my network
39% adoption rate in Canada? This is probably heavily skewed by mobile users, because cable/DSL/FTTH ISPs are largely still IPv4-only. My ISP is a local exception, as they provide a static /56 PD.
I have it enabled and configured mostly because "why not". IPv6 is currently something that mostly just works in background, just like even IPv4 is something that largely works quietly in the background for the vast majority of home users.
yes
IPV6 settings
and my modem supports it native even in bridge mode
my country not widely supports it
Vodafone UK have dual stack with /56 PD. I'm using it because it just works, but some users are experiencing problems with the ISP provided routers. Prioritizes IPv6, and will failover to IPv4.
No-one wants a reverse DNS on IPv6.
LTE and 5G must support IPv6 per 3GPP specs, which answers the mobile item...
It's been in the background as link-local traffic for a long time now - the whole fe80 prefix...
For the most part, most folks shouldn't see that much of an impact - it should actually be transparent...
