1 - I had my DS1819+ working on the satellite of a Velop mesh network. All of the sudden, I couldn't access it. I called into Synology and we found that it just couldn't use the satellite at all - even though it previously did. As soon as I plugged it into the main router, it worked fine. What kind of troubleshooting would you do to try to find out why the system would not work on a satellite? I really would prefer to have the system in the room where I had it before. Yes, I have tried to just move it back and it isn't recognizing the network.
2 - Have any of you setup Kitana on a Synology? If so, do you have any documentation you can share?
3 - Which would you recommend setting up - Telly or xTeVe on a Plex server that resides on a DS1819+? Is there any recommended sites that details exactly what is needed to be done to get it up and working for even an idiot like me?
