P
palmada
Guest
Hello all.
I have a question, if it's not much of a bother: if I have my computer connected (apparently) why can't I access anything on the network, internet or even the router page? Windows says "I'm connected!" but it's a damn, filthy lie.
I have a new Belkin N1 Vision, on channel 1 (I've looked, it would appear to be the only network on channel 1 around). It has WPA2 on and it broadcasts an SSID. I've disabled the WPA2 and even the firewall to no avail.
It doesn't appear to be a problem with DHCP, all computers have an auto-assigned IP, I can even get an IP I designate manually. I've even assigned my DNS's manually (doesn't work). When I use a cable to check the DHCP list, everything looks just dandy. The router is said to be plagued by issues fixed with a pre-release firmware, that currently sits on the flash on my router. Needless to say, I can tell no difference to the old firmware.
The network currently boasts 2 desktops (one b, one n) and 2 laptops (both g). The desktop that's most problematic has a Conceptronic PCI n card (with the fancy pantsy 3 antennae) that's on the underside of a desk. It's on the second floor (router is on the first floor) and my house certainly has lot's of concrete walls, but the laptops connect. My laptop (what I'm on now) is sitting right next to the n computer and has a great connection almost always, so it wouldn't be a reception issue. Although we use a cordless phone, it's on a different room of the house than the n computer. The microwave is far away as well. The b desktop that also has issues, connects only partially more often and sits right next to the cordless phone.
The connection itself varies greatly. In the brief moments I've connected, I have great speeds for a few seconds, then it goes downhill. Most of the time, it connects and even though it reports a connection (and the windows reported speed varies over time) I can't actually access anything.
Rebooting router and computers has only worked once out of 20 tries.
I've bought the router because my old ASUS router was very unstable. I KNEW I had connection issues with the that one because windows said as much, and at least all computers on the first floor connected. But I read reviews of this N1 Vision router that sounded promising (including the one on SNB) and for a few days if worked fine. But I hate the fact that with this router, Windows is actually lying to me.
I can't understand the problem here... It would appear to be a terrible hardware issue on the router's side. At this point, I'm writing this mostly to vent, since I'm set on returning the router and buying a solid g router (make the whole house a g network). However, if anyone on this forum has some insight, it would be deeply, deeply appreciated.
