A silly question re bootloader version
Hi all,
Very basic but how do you check which version of boot loader you are running?
Thanks Slav
you can use:
nvram get bl_version
Or under tools => Bootloader (CFE)
you can use:
This command will show some value from NVRAM. It will be the same even after bootloader update, until you'll reset settings to factory default values. Too see CFE version please use:
strings /dev/mtd0ro | grep bl_version
