AB-Solutions Certificate Error on Mac and iPhone
Wycleff
Im using my Router for a long time now in combination with AB-Solutions.
Everything works fine but on my Mac and my iPhone, i get this nasty certificate Error's on google or Youtube etc.
“Safari can’t verify the identity of the website “static.ak.google.com”
The certificate for this website is invalid. You might be connecting to a website that is pretending to be “static.ak.google.com”, which could put your confidential information at risk. Would you like to connect to the website anyway?”
Is there an solutions to disable this shirtty Certificate-Popup's?
I can set them to trusted but by doing this, more and more Ads pop up over time.
Thanks for helping !
-----FIXED IT-----
COPY'ED THE FROM PIXELSERV GENERATED CA.CRT FILE FROM THE ROUTER TO MY MAC AND IMPORTED IT.
WORKED ALSO FOR MY IOS DEVICE VIA APPLE CONFIGURATOR.
LOCATION -> ROUTER-IP-> /opt/var/cache/pixelserv
Thank you @
thelonelycoder
-----FIXED IT-----
Thank you @
thelonelycoder
The copying of that file will get a lot easier with the upcoming release. It has a backup function that includes that file.
