Specifically for the QNAP TVS-671 model with the Dual-core Intel G3250 3.2 GHz Processor, would it be a plug in and play to replace it with an i5 or i7?
As long as you stay within the same processor family - e.g. Haswell in your case with the G3250, you should be fine...
FWIW - might not need that much more horsepower - so unless you get a really good deal, you might be better off where you are.
I suppose the worst case - if things blow up, QNAP could always reject a warranty claim, but I haven't heard or seen anything that would suggest this is the case.
Indeed. I'm not too worried about the warranty as that's pretty much null from the moment my mind even thinks about an engine swap.
My buddy has the TVS-871 and he has successfully upgraded his CPU to the i7. It seems to flying....it's very noticeable.
Well, if you're ok with the warranty - that's cool...
One other consideration - shop careful on the i3/i5/i7 vs. the Pentium G3250 - not just processor architecture, you want to hit the same thermals... the G3250 is a 53W TDP processor, to stay within the heat-sink/cooler capability, you want to be same on the i3/i5/i7...
So an i7-4790, which is the same socket, is likely not a good candidate, as it's an 84W processor...
I forgot to upload this. i7-4790S transplant successful.
Now the TVS-671 is powered by the Quad Core 3.2HGz (i7) with 16GB or RAM. It's fast. Real fast.
Cool - hard to justify though - how to define/measure what "real fast" is? Esp. on a SOHO LAN - might be different in the enterprise space, but when looking at the typical SNB userspace here - it's probably overkill.
On a GiGE lan - most modern NAS boxes can saturate the network before the CPU is pegged at max..
(but the HW hacker guy in me, I do appreciate the need for speed, lol)
Sure, it's overkill for 99.9% of the users on SNB LOL...I agree, but knowing what's possible is sometimes just as reassuring as actually doing it
Welcome To SNBForums
