about ipset --add setmefree 91.108.56.0/22
chu
I use:
ipset --add setmeok 91.108.56.0/22
and I can't find it from the ip list via command
ipset -L setmeok
is something wrong?
I use:
ipset -L setmeok
is something wrong?
No, you need to create a separate type of ipset, nethash, to be able to handle CIDR addresses.
That firmware still uses ipset version 4, so.....
You need to create an ipset that handles CIDR address (unfortunately you can't mix single addresses and CIDR addresses in a single set, and trying to fake it out with a /32 mask doesn't work either). The set type is nethash. You may need to modprobe ip_set_nethash if you already aren't doing so.
ipset -N newsetname nethash
Then add your CIDR addresses to this new ipset.
Now, in order to keep from having to add a new ipset to your iptables rules, you can join multiple ipsets under a new set name. First create another ipset that is a list of ipsets
ipset -N ipsetlistname setlist
Now add your ipsets to the setlist
ipset --add ipsetlistname newsetname
ipset --add ipsetlistname setmeok (using your old ipset as an example. You could of course make two new ipsets , and make the ipsetlistname = setmeok to avoid having to change your iptables rules).
Note that you still have to add individual ips/CIDRs to the base ipsets, not the setlist.
how about upgrade my router to 380.63?
I saw it has ipset 6.29, so can I use "ipset --add setmefree 91.108.56.0/22" directly?
No, sorry....same restrictions/methodology applies. But the syntax has changed (although I think it's backwards compatible, except for the module names)
module name ip_set_nethash >> ip_set_hash_net (ipset 6 will automatically load this module for you)
instead of loading ipt_set you need to load module xt_set for iptables support
ipset -N >> ipset --create
settype nethash >> hash:net
settype setlist >> list:set
And I think there are some fixes for the list:set support in ipset 6.
i found a idea on the web, is it ok with merlin?
iptables -t nat -A PREROUTING -p tcp -d 91.108.56.0/22 -j REDIRECT --to-ports 3333
