AC-3200 cannot upgrade from 380.66_beta5-gfccc157 is this a known issue?
Retsujou
Hello there.
I am trying to go form 380.66_beta5-gfccc157 to the latest 380.67-beta2. No matter which browser I use the firmware, after reboot, seems to be the same.
I am not really that familiar with the log layout, so I am not sure which logs to check. I am very happy on unix based systems, so if you tell me what extra information you need I would be happy to oblige.
Otherwise is there a way to force the upgrade using scp as the transport mechanism for the upgrade file?
ASUSWRT-Merlin RT-AC3200 380.66-beta5-gfccc157
Thank you.
Hello there.
Thank you.
Do you have any USB devices plugged in? If so, unmount and remove them. There is the firmware recovery tool ASUS has. They describe how to use it on their support site.. On the first AC88U I bought, I was unable to flash Merlin using the web gui or the recover tool. I ended up using the tftp process described on the dd-wrt.com forum site and that ended up working for me. Except I used Merlin FW and not dd-wrt. I have always flashed from the web gui ever since.
http://www.dd-wrt.com/wiki/index.php/Asus_TFTP_Flash
