AC-68U Vpn client & server
ablitz
I'm trying to get my setup with one vpn server & one client working.
If I only use the server I can connect and all is fine. It's also working fine if I'm only running the client.
If I attempt to connect via a remote connection and both are enabed, I can't connect to the server (using eth0 address), it stalls at establishing connection and I just get W on the prompt. The client is working as intended and keeps routing all traffic over the vpn.
If I attempt to connect via LAN and both are enabled, I can connect to the server but no connection to eth0 or tun11. The client is working as above.
What I would like is to be able to connect to the vpn server from a remote location and access my internal network and access internet through the vpn client.
Router FW 378.50 (have had same problem with 376.49)
On the client
Create NAT on tunnel - yes
Redirect Internet traffic - yes
Client is using a public ip address for the vpn
On the server
Push LAN to clients - yes
Direct clients to redirect Internet traffic - yes
If anyone with some routing knowledge could help me out it would be highly appriciated.
