AC-86U OpenVPN CA certificate cannot be changed
bobo27
I just switched from an AC-66U to an AC-86U (384.10). I used the AC-66U with the last firmware version available (April 2018), so I decided to upgrade.
I had everything working on the AC-66U, including OpenVPN and DDNS, but I'm struggling to get the same setup working on the AC-86U.
I have already factory reset the AC-86U and started from scratch but I can't get OpenVPN to work. I have copied the same keys and certificates as I had on the AC-66U, but the AC-86U keeps overwriting the CA.crt field with its own after I press apply.
How can I get the AC-86U to accept my own CA.crt?
