AC-87U Broken GUI in the port forwarding list menu
Sangyoun Han
I have issue about broken gui for port forwarding list menu.
please let me know the solution to issue.
In addition , Could you please to guide how to change language from japanese to english.
Routers sold in Japanese are locked to the Japanese language for their web interface.
@Sangyoun Han ,
1. Which firmware version do you use? the lastest one? we will help to check the broken GUI on port-forwarding.
2. As Merlin said, we don't allow to change language for Japan.
Thanks,
Vanic
For your port forward issue, I recommend clearing up the saved list in case it was corrupted. Enable SSH or telnet, connect to your router using a tool such as Putty or Xshell5, then run the following command:
nvram unset vts_rulelist
nvram commit
This will clear any existing port forward.
Is it possible that the google translation function cause this problem during setting port forwarding ?
I don't understand japanese. So I used the chrome translation while using web interface to set port forwarding. After finishing setting , I found that the broken gui occurred.
If it's true, It's better to provide the changing method from japanese to another language.
