Decompressing...done
CFE version 7.14.131.1608 (r589038) based on BBP 1.0.37 for BCM947XX (32bit,SP,)
Build Date: 二 10月 13 18:19:30 CST 2015 (ham@xpdev)
Copyright (C) 2000-2008 Broadcom Corporation.
Init Arena
Init Devs.
Boot partition size = 262144(0x40000)
DDR Clock: 800 MHz
Info: DDR frequency set from clkfreq=1400,*800*
et1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.1608 (r589038)
CPU type 0x0: 1400MHz
Tot mem: 524288 KBytes
CFE mem: 0x00F00000 - 0x017ABEC8 (9092808)
Data: 0x00F5401C - 0x00F549C4 (2472)
BSS: 0x00F549D0 - 0x00FA9EC8 (349432)
Heap: 0x00FA9EC8 - 0x017A9EC8 (8388608)
Stack: 0x017A9EC8 - 0x017ABEC8 (8192)
Text: 0x00F00000 - 0x00F4A1E0 (303584)
rtl8354mb initialized(0)(retry 0)
rtk port_phyEnableAll ok
rtk port_macForceLink_set ext_Port1 ok
get ok, chk 0x1311:1016(0x1016), 0x1305:c010(b4~b7:0x1)
Device eth0: hwaddr F8-32-E4-52-94-38, ipaddr 192.168.1.1, mask 255.255.255.0
gateway not set, nameserver not set
Null Rescue Flag.
boot the image...
go load
Loader:raw Filesys:tftp Dev:eth0 File:: Options
null)
Loading: TFTP Server.
..tftp retry wait 0
Failed.
Could not load :: Timeout occured
Loader:raw Filesys:raw Dev:nflash0.os File: Options
null)
Loading: .... 4367776 bytes read
Entry at 0x00008000
Closing network.
Starting program at 0x00008000
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117) is a 16550
brd: module loaded
loop: module loaded
pflash: found no supported devices
bcmsflash: found no supported devices
Boot partition size = 524288(0x80000)
lookup_nflash_rootfs_offset: offset = 0x200000
nflash: squash filesystem with lzma found at block 29
Creating 4 MTD partitions on "nflash":
0x000000000000-0x000000080000 : "boot"
0x000000080000-0x000000200000 : "nvram"
0x000000200000-0x000004000000 : "linux"
0x0000003b61c8-0x000004000000 : "rootfs"
PPP generic driver version 2.4.2
PPP MPPE Compression module registered
NET: Registered protocol family 24
PPTP driver version 0.8.5
=== PPTP init ===
Mirror/redirect action on
u32 classifier
Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (8047 buckets, 32188 max)
ctnetlink v0.93: registering with nfnetlink.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
L2TP core driver, V2.0
PPPoL2TP kernel driver, V2.0
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
Registering the dns_resolver key type
Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2012
NAND device: Manufacturer ID: 0xc8, Chip ID: 0xd1 (Unknown NAND 128MiB 3,3V 8-bit)
Spare area=64 eccbytes 56, ecc bytes located at:
2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Available 7 bytes at (off,len):
(1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
Scanning device for bad blocks
Options: NO_AUTOINCR,NO_READRDY,
Creating 1 MTD partitions on "brcmnand":
0x000004000000-0x000008000000 : "brcmnand"
VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
devtmpfs: mounted
Freeing init memory: 288K
## mknod /dev/null: File exists
## mknod /dev/console: File exists
1: set_action 0
Hit ENTER for console...
firmware version: 3.0.0.4.380.64_2
killall_tk: waiting name=envrams n=9
killall_tk: waiting name=envrams n=8
killall_tk: waiting name=envrams n=7
killall_tk: waiting name=envrams n=6
killall_tk: waiting name=envrams n=5
killall_tk: waiting name=envrams n=4
killall_tk: waiting name=envrams n=3
killall_tk: waiting name=envrams n=2
killall_tk: waiting name=envrams n=1
killall_tk: waiting name=envrams n=0
killall_tk: SIGKILL name=envrams n=9
killall_tk: SIGKILL name=envrams n=8
killall_tk: SIGKILL name=envrams n=7
killall_tk: SIGKILL name=envrams n=6
killall_tk: SIGKILL name=envrams n=5
killall_tk: SIGKILL name=envrams n=4
killall_tk: SIGKILL name=envrams n=3
killall_tk: SIGKILL name=envrams n=2
killall_tk: SIGKILL name=envrams n=1
killall_tk: SIGKILL name=envrams n=0
_ifconfig: name=lo flags=1043 IFUP addr=127.0.0.1 netmask=255.0.0.0
route_manip: cmd=ADD name=lo addr=127.0.0.0 netmask=255.0.0.0 gateway=0.0.0.0 metric=0
[1 preinit:init_nvram +10] init_nvram for model(47)
## Restoring defaults... ##
num_of_mssid_support(0x0093): [mssid] support [3] mssid
done
gmac3_override_nvram
rtl8365mb: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
rtl8365mbrtl8365mb initialized(0)(retry:1)
register rtl8365mb done (link down at first)
et_module_init: passivemode set to 0x0
et_module_init: txworkq set to 0x0
et_module_init: et_txq_thresh set to 0xce4
et_module_init: et_rxlazy_timeout set to 0x3e8
et_module_init: et_rxlazy_framecnt set to 0x20
et_module_init: et_rxlazy_dyn_thresh set to 0
fwd0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.4402 (r628786)
fwd1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.4402 (r628786)
eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.4402 (r628786)
hotplug net INTERFACE=fwd1 ACTION=add
hotplug net INTERFACE=fwd0 ACTION=add
hotplug net INTERFACE=eth0 ACTION=add
hotplug net INTERFACE=agg ACTION=add
config_location(0x003b): [tcode] location is []
config_location(0x003d): [tcode] no location setting, using default location
config_location(0x0053): [tcode] config location: [0:ccode]=[Q2], [0:regrev]=[992]
config_location(0x005d): [tcode] set_wl_country, 0, [Q2], [992]
config_location(0x0073): [tcode] config location 5G: [1:ccode]=[Q2], [1:regrev]=[992]
config_location(0x007e): [tcode] set_wl_country, 1, [Q2], [992]
set_wltxpower(0x023b): unit: 0, txpower: 100
set_wltxpower(0x023b): unit: 1, txpower: 100
hotplug net INTERFACE=dpsta ACTION=add
PCI_PROBE: bus 1, slot 0,vendor 14E4, device 4365(good PCI location)
PCI: Enabling device 0001:01:00.0 (0140 -> 0142)
dhd_attach(): thread:dhd_watchdog_thread:183 started
ring_info_raw: 56
dc 53 3f 00 ac 64 3f 00 c0 66 3f 00 d4 68 3f 00
da 68 3f 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 0a 01 00 00
CUR_ETHERADDR : 6
f8 32 e4 52 94 38
Dongle Host Driver, version 1.369.1 (r628771)
Compiled in drivers/net/wireless/bcmdhd on May 30 2016 at 14:06:44
Register interface [eth1] MAC: f8:32:e4:52:94:38
PCI: Enabling device 0002:01:00.0 (0140 -> 0142)
hotplug net INTERFACE=eth1 ACTION=add
dhd_attach(): thread:dhd_watchdog_thread:187 started
External imprecise Data abort at addr=0xa3000000, fsr=0x1406, pc=0x8030f234 lr=0x7f08947c ignored.
^C
^C^C^C
Digital core power voltage set to 1.05V
