timredfern
This is driving me up the wall.
I bought the AC-RT66U to set up load balancing in a small office.
I've tried the official firmware and various versions of Merlin including the latest.
I'm seeing the following:
If I turn on dual WAN (in either mode) the service bombs. Clients (both wired and wireless) lose internet connectivity constantly (although not actually disconnected). I also see crazy variable latency especially on 5Ghz wireless, of up to 2 seconds.
If I go back to single WAN the service is more reliable but still has 'episodes' where clients lose connectivity. Latency is still very variable: on 5Ghz for example I'm seeing this:
64 bytes from 173.194.112.63: icmp_seq=1138 ttl=53 time=32.804 ms
64 bytes from 173.194.112.63: icmp_seq=1139 ttl=53 time=38.706 ms
64 bytes from 173.194.112.63: icmp_seq=1140 ttl=53 time=32.930 ms
64 bytes from 173.194.112.63: icmp_seq=1141 ttl=53 time=35.190 ms
64 bytes from 173.194.112.63: icmp_seq=1142 ttl=53 time=34.503 ms
64 bytes from 173.194.112.63: icmp_seq=1143 ttl=53 time=50.532 ms
64 bytes from 173.194.112.63: icmp_seq=1144 ttl=53 time=100.826 ms
64 bytes from 173.194.112.63: icmp_seq=1145 ttl=53 time=147.947 ms
64 bytes from 173.194.112.63: icmp_seq=1146 ttl=53 time=188.270 ms
64 bytes from 173.194.112.63: icmp_seq=1147 ttl=53 time=230.915 ms
64 bytes from 173.194.112.63: icmp_seq=1148 ttl=53 time=247.214 ms
64 bytes from 173.194.112.63: icmp_seq=1149 ttl=53 time=33.361 ms
64 bytes from 173.194.112.63: icmp_seq=1150 ttl=53 time=33.834 ms
64 bytes from 173.194.112.63: icmp_seq=1151 ttl=53 time=35.470 ms
64 bytes from 173.194.112.63: icmp_seq=1152 ttl=53 time=45.432 ms
64 bytes from 173.194.112.63: icmp_seq=1153 ttl=53 time=37.091 ms
64 bytes from 173.194.112.63: icmp_seq=1154 ttl=53 time=32.407 ms
64 bytes from 173.194.112.63: icmp_seq=1155 ttl=53 time=70.876 ms
64 bytes from 173.194.112.63: icmp_seq=1156 ttl=53 time=113.718 ms
64 bytes from 173.194.112.63: icmp_seq=1157 ttl=53 time=156.980 ms
64 bytes from 173.194.112.63: icmp_seq=1158 ttl=53 time=208.234 ms
64 bytes from 173.194.112.63: icmp_seq=1159 ttl=53 time=252.142 ms
64 bytes from 173.194.112.63: icmp_seq=1160 ttl=53 time=35.845 ms
64 bytes from 173.194.112.63: icmp_seq=1161 ttl=53 time=54.509 ms
64 bytes from 173.194.112.63: icmp_seq=1162 ttl=53 time=59.040 ms
64 bytes from 173.194.112.63: icmp_seq=1163 ttl=53 time=42.374 ms
64 bytes from 173.194.112.63: icmp_seq=1164 ttl=53 time=32.967 ms
64 bytes from 173.194.112.63: icmp_seq=1165 ttl=53 time=33.778 ms
64 bytes from 173.194.112.63: icmp_seq=1166 ttl=53 time=39.814 ms
64 bytes from 173.194.112.63: icmp_seq=1167 ttl=53 time=91.781 ms
64 bytes from 173.194.112.63: icmp_seq=1168 ttl=53 time=134.492 ms
64 bytes from 173.194.112.63: icmp_seq=1169 ttl=53 time=179.720 ms
64 bytes from 173.194.112.63: icmp_seq=1170 ttl=53 time=243.224 ms
64 bytes from 173.194.112.63: icmp_seq=1171 ttl=53 time=257.566 ms
When I connect directly to DSL by ethernet the latency is solid 7ms. What the hell is the ASUS router doing?
The ASUS logs show clients are contantly performing DHCP requests:
Nov 17 13:11:43 dnsmasq-dhcp[290]: DHCPREQUEST(br0) 192.168.2.131 18:ee:69:0a:db:16
Nov 17 13:11:43 dnsmasq-dhcp[290]: DHCPACK(br0) 192.168.2.131 18:ee:69:0a:db:16 Apple-TV-2
Nov 17 13:12:55 dnsmasq-dhcp[290]: DHCPREQUEST(br0) 192.168.2.131 18:ee:69:0a:db:16
Nov 17 13:12:55 dnsmasq-dhcp[290]: DHCPACK(br0) 192.168.2.131 18:ee:69:0a:db:16 Apple-TV-2
Nov 17 13:14:07 dnsmasq-dhcp[290]: DHCPREQUEST(br0) 192.168.2.131 18:ee:69:0a:db:16
Nov 17 13:14:07 dnsmasq-dhcp[290]: DHCPACK(br0) 192.168.2.131 18:ee:69:0a:db:16 Apple-TV-2
Nov 17 13:14:55 dnsmasq-dhcp[290]: DHCPREQUEST(br0) 192.168.2.131 18:ee:69:0a:db:16
Nov 17 13:14:55 dnsmasq-dhcp[290]: DHCPACK(br0) 192.168.2.131 18:ee:69:0a:db:16 Apple-TV-2
Nov 17 13:16:07 dnsmasq-dhcp[290]: DHCPREQUEST(br0) 192.168.2.131 18:ee:69:0a:db:16
Nov 17 13:16:07 dnsmasq-dhcp[290]: DHCPACK(br0) 192.168.2.131 18:ee:69:0a:db:16 Apple-TV-2
When Dual WAN is active I seem to be seeing errors like this:
Nov 17 11:04:08 dnsmasq-dhcp[290]: DHCPREQUEST(br0) 192.168.43.58 24:24:0e:c1:55:31
Nov 17 11:04:08 dnsmasq-dhcp[290]: DHCPNAK(br0) 192.168.43.58 24:24:0e:c1:55:31 wrong network
The router is not overloaded. The largest number of clients it has had is 21, at the moment cpu usage is 2-3% and 27% memory used.
Has anyone used the AC-RT66U sucessfully with or without dual WAN? I'm about to throw it out.
Tim Redfern
Tim Redfern
