The RT-AC68U is my main router on the 2nd floor and the wireless range is good but it doesn't extend to the back of my garage. Would it be a good idea to use my old N66U as an extender for the 2.4 ghz channel only through wireless? Would that half the throughput of the 2.4 ghz channel? The N66U is just collecting dust so I either need to use it or sell it.
Is it generally only recommended to use an extender if you can get a wired connection to the spot? Would be difficult to do since my house was not wired for ethernet.
