P
Pir8pete
Guest
Seems that I'm getting an error in my routers logs when accessing the connected USB3 hard drive and transferring files, see below.
I was also having an issue with the speed not going over 2mb/s. I had "Reducing USB 3.0 interference" org. disabled when setting up. So I re-enabled it, saved then disabled it saved. Now I get 70mb/s when pulling a file from the drive and 50mb/s when uploading a file to the drive. It's better now but why is uploading a file slower?
I also noticed after accessing the drive and getting these errors below the router will disconnect my lan PC briefly. Also notice that my Logitech Alert 750e Outdoor Master System will not connect some times after a reboot of the router. I had a Dark Knight and then the AC66 and never had any of these issues.
Using fw RT-AC68U_380.65_2
Jul 31 20:00:26 kernel: scsi 0:0:0:0: Direct-Access WD My Passport 0827 1012 PQ: 0 ANSI: 6
Jul 31 20:00:26 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Jul 31 20:00:26 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jul 31 20:00:26 kernel: sd 0:0:0:0: [sda] Spinning up disk...
Jul 31 20:00:26 kernel: scsi 0:0:0:1: Enclosure WD SES Device 1012 PQ: 0 ANSI: 6
Jul 31 20:00:26 kernel: scsi 0:0:0:1: Attached scsi generic sg1 type 13
Jul 31 20:00:27 kernel: .
Jul 31 20:00:27 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Jul 31 20:00:27 kernel: xhci_hcd 0000:00:0c.0: WARN Event TRB for slot 1 ep 2 with no TDs queued?
Jul 31 20:00:28 kernel: .
Jul 31 20:00:28 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Jul 31 20:00:28 kernel: xhci_hcd 0000:00:0c.0: WARN Event TRB for slot 1 ep 2 with no TDs queued?
Jul 31 20:00:29 kernel: .
Jul 31 20:00:29 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Jul 31 20:00:29 kernel: xhci_hcd 0000:00:0c.0: WARN Event TRB for slot 1 ep 2 with no TDs queued?
Jul 31 20:00:30 kernel: .
Jul 31 20:00:30 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Jul 31 20:00:31 kernel: .
Jul 31 20:00:31 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Jul 31 20:00:31 kernel: xhci_hcd 0000:00:0c.0: WARN Event TRB for slot 1 ep 2 with no TDs queued?
Jul 31 20:00:32 kernel: .
Jul 31 20:00:32 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Jul 31 20:00:33 kernel: .ready
Jul 31 20:00:33 kernel: sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
Jul 31 20:00:33 kernel: sd 0:0:0:0: [sda] 5860466688 512-byte logical blocks: (3.00 TB/2.72 TiB)
Jul 31 20:00:33 kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
Jul 31 20:00:33 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Jul 31 20:00:33 kernel: sd 0:0:0:0: [sda] Write Protect is off
Jul 31 20:00:33 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Jul 31 20:00:33 kernel: sda: sda1 sda2
Jul 31 20:00:33 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Jul 31 20:00:33 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Jul 31 20:00:33 hotplug[850]: USB /dev/sda2(ntfs) failed to mount at the first try!
Jul 31 20:00:33 usb: USB /dev/sda2(ntfs) failed to mount At the first try!
Jul 31 20:00:33 kernel: tntfs error (device sda2, pid 868): parse_options(): Unrecognized mount option sparse.
Jul 31 20:00:33 kernel: tfat: fail_safe is enabled
Jul 31 20:00:33 kernel: tntfs info (device sda2, pid 870): ntfs_fill_super(): fail_safe is enabled
Jul 31 20:00:33 kernel: tntfs info (device sda2, pid 870): load_system_files(): NTFS volume name 'Backup', version 3.1 (cluster_size 4096, PAGE_CACHE_SIZE 4096).
Jul 31 20:00:34 kernel: nf_conntrack_rtsp v0.6.21 loading
Jul 31 20:00:34 kernel: nf_nat_rtsp v0.6.21 loading
Jul 31 20:00:35 syslog: USB ntfs fs at /dev/sda2 mounted on /tmp/mnt/Backup
Jul 31 20:00:35 usb: USB ntfs fs at /dev/sda2 mounted on /tmp/mnt/Backup.
Jul 31 20:00:35 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Mar 20 03:20:24 smbd[2021]: [2017/03/20 03:20:24.267922, 0] ../libcli/auth/ntlm_check.c:54(smb_pwd_check_ntlmv1)
Mar 20 03:20:24 smbd[2021]: smb_pwd_check_ntlmv1: incorrect password length (74)
Mar 20 03:20:24 smbd[2021]: [2017/03/20 03:20:24.269109, 0] ../libcli/auth/ntlm_check.c:54(smb_pwd_check_ntlmv1)
