AC3100 Check Sum Not matching.
S C
I have downloaded the newest stable Merlin Firmware for the AC3100 from both the main site and the mirror, but neither of them gives me a file where the SHA256 check sum matches what is posted on the site. I am checking the .trx file after unzipping it to the desktop. Is this the correct file to check or should I be checking another file?
Works for me. The checksum matches that of the trx file after it's been extracted from the zip.
eaaeb17533a57ab00e8aa0f2734d9d48dff0d6aa8e9c74e5488370fd5d8fa70a RT-AC3100_384.13_0.trx
Try unzipping it to somewhere other than your desktop. If it still doesn't work check that your anti-virus isn't corrupting the extraction process.
Works for me also. They are identical: RT-AC3100_384.13_0.trx
Main download site
Mirror
sha256sum.sha256
Thank you. Not sure what is going on... Tried it on mac and PC with the same result on both. Maybe I'll try another browser...
I'd suggest the terminal.
