The Fourth Doctor
Am I crazy or do I have a hardware issue? I can only get the 5G network operating on my AC3100. The weird part is that, in the web interface, the 2.4G settings page controls the 5G network, and the 5G network simply shows channel 0 and no settings take effect. What I think has happened is that there is a hardware issue with the 2.4G device, which would normally be eth1, and because it doesn't register the 5G gets registered as eth1 instead, and the GUI just assumes that it's 2.4G.
In trying to fix this I've upgraded/downgraded firmware and erased the nvram several times.
If it isn't a hardware issue, is there a way to "force" the registration of the 2.4G device on boot? I've been playing around via the ssh shell, but to no avail.
System log follows, relevant lines in blue:
Jul 31 20:00:39 syslogd started: BusyBox v1.17.4
Jul 31 20:00:39 kernel: klogd started: BusyBox v1.17.4 (2016-05-18 16:34:01 CST)
Jul 31 20:00:39 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #3 SMP PREEMPT Wed May 18 16:40:37 CST 2016
Jul 31 20:00:39 kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
Jul 31 20:00:39 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Jul 31 20:00:39 kernel: Machine: Northstar Prototype
Jul 31 20:00:39 kernel: Ignoring unrecognised tag 0x00000000
Jul 31 20:00:39 kernel: Memory policy: ECC disabled, Data cache writealloc
Jul 31 20:00:39 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
Jul 31 20:00:39 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Jul 31 20:00:39 kernel: Memory: 515036k/515036k available, 9252k reserved, 0K highmem
Jul 31 20:00:39 kernel: Virtual kernel memory layout:
Jul 31 20:00:39 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Jul 31 20:00:39 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Jul 31 20:00:39 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB)
Jul 31 20:00:39 kernel: vmalloc : 0xa0800000 - 0xf0000000 (1272 MB)
Jul 31 20:00:39 kernel: lowmem : 0x80000000 - 0xa0000000 ( 512 MB)
Jul 31 20:00:39 kernel: modules : 0x7f000000 - 0x80000000 ( 16 MB)
Jul 31 20:00:39 kernel: .init : 0x80008000 - 0x80050000 ( 288 kB)
Jul 31 20:00:39 kernel: .text : 0x80050000 - 0x803f1000 (3716 kB)
Jul 31 20:00:39 kernel: .data : 0x8040a000 - 0x8042e400 ( 145 kB)
Jul 31 20:00:39 kernel: External imprecise Data abort at addr=0x0, fsr=0x1c06, pc=0x8000f9d8 lr=0x8000f9cc ignored.
Jul 31 20:00:39 kernel: Mount-cache hash table entries: 512
Jul 31 20:00:39 kernel: CPU1: Booted secondary processor
Jul 31 20:00:39 kernel: Found a Zentel/Esmt NAND flash:
Jul 31 20:00:39 kernel: Total size: 128MB
Jul 31 20:00:39 kernel: Block size: 128KB
Jul 31 20:00:39 kernel: Page Size: 2048B
Jul 31 20:00:39 kernel: OOB Size: 64B
Jul 31 20:00:39 kernel: Sector size: 512B
Jul 31 20:00:39 kernel: Spare size: 16B
Jul 31 20:00:39 kernel: ECC level: 8 (8-bit)
Jul 31 20:00:39 kernel: Device ID: 0xc8 0xd1 0x80 0x95 0x42 0x7f
Jul 31 20:00:39 ntp: start NTP update
Jul 31 20:00:39 kernel: ACP (Accelerator Coherence Port) enabled
Jul 31 20:00:39 kernel: bio: create slab <bio-0> at 0
Jul 31 20:00:39 kernel: PCI: no core
Nov 24 18:30:13 rc_service: ntp 485:notify_rc restart_diskmon
Nov 24 18:30:13 kernel: PCI: Fixing up bus 0
Nov 24 18:30:13 kernel: PCI: Fixing up bus 1
Nov 24 18:30:13 kernel: VFS: Disk quotas dquot_6.5.2
Nov 24 18:30:13 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Nov 24 18:30:13 kernel: pflash: found no supported devices
Nov 24 18:30:13 kernel: bcmsflash: found no supported devices
Nov 24 18:30:13 kernel: Boot partition size = 524288(0x80000)
Nov 24 18:30:13 kernel: lookup_nflash_rootfs_offset: offset = 0x200000
Nov 24 18:30:13 kernel: nflash: squash filesystem with lzma found at block 29
Nov 24 18:30:13 kernel: Creating 4 MTD partitions on "nflash":
Nov 24 18:30:13 kernel: 0x000000000000-0x000000080000 : "boot"
Nov 24 18:30:13 kernel: 0x000000080000-0x000000200000 : "nvram"
Nov 24 18:30:13 kernel: 0x000000200000-0x000004000000 : "linux"
Nov 24 18:30:13 kernel: 0x0000003b39e8-0x000004000000 : "rootfs"
Nov 24 18:30:13 kernel: === PPTP init ===
Nov 24 18:30:13 kernel: Registering the dns_resolver key type
Nov 24 18:30:13 kernel: Spare area=64 eccbytes 56, ecc bytes located at:
Nov 24 18:30:13 kernel: 2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Nov 24 18:30:13 kernel: Available 7 bytes at (off,len):
Nov 24 18:30:13 kernel: (1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
Nov 24 18:30:13 kernel: Bad eraseblock 250 at 0x000001f40000
Nov 24 18:30:13 kernel: Options: NO_AUTOINCR,NO_READRDY,
Nov 24 18:30:13 kernel: Creating 1 MTD partitions on "brcmnand":
Nov 24 18:30:13 kernel: 0x000004000000-0x000008000000 : "brcmnand"
Nov 24 18:30:13 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
Nov 24 18:30:13 kernel: ctf: module license 'Proprietary' taints kernel.
Nov 24 18:30:13 kernel: Disabling lock debugging due to kernel taint
Nov 24 18:30:13 kernel: et_module_init: passivemode set to 0x0
Nov 24 18:30:13 kernel: et_module_init: txworkq set to 0x0
Nov 24 18:30:13 kernel: et_module_init: et_txq_thresh set to 0xce4
Nov 24 18:30:13 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8
Nov 24 18:30:13 kernel: et_module_init: et_rxlazy_framecnt set to 0x20
Nov 24 18:30:14 kernel: et_module_init: et_rxlazy_dyn_thresh set to 0
Nov 24 18:30:14 kernel: fwd0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.4402 (r628786)
Nov 24 18:30:14 kernel: fwd1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.4402 (r628786)
Nov 24 18:30:14 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.4402 (r628786)
Nov 24 18:30:14 kernel: PCI_PROBE: bus 1, slot 0,vendor 14E4, device 4365(good PCI location)
Nov 24 18:30:14 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142)
Nov 24 18:30:14 kernel: dhd_attach(): thread:dhd_watchdog_thread:16f started
Nov 24 18:30:14 kernel: dhd_detach(): thread:dhd_watchdog_thread:16f terminated OK
Nov 24 18:30:14 kernel: dhd_attach(): thread:dhd_watchdog_thread:170 started
Nov 24 18:30:14 kernel: dhd_detach(): thread:dhd_watchdog_thread:170 terminated OK
Nov 24 18:30:14 kernel: dhd_attach(): thread:dhd_watchdog_thread:171 started
Nov 24 18:30:14 kernel: dhd_detach(): thread:dhd_watchdog_thread:171 terminated OK
Nov 24 18:30:14 kernel: dhd_attach(): thread:dhd_watchdog_thread:172 started
Nov 24 18:30:14 kernel: dhd_detach(): thread:dhd_watchdog_thread:172 terminated OK
Nov 24 18:30:14 kernel: dhd_attach(): thread:dhd_watchdog_thread:173 started
Nov 24 18:30:14 kernel: dhd_detach(): thread:dhd_watchdog_thread:173 terminated OK
Nov 24 18:30:14 kernel: PCI: Enabling device 0002:01:00.0 (0140 -> 0142)
Nov 24 18:30:14 kernel: dhd_attach(): thread:dhd_watchdog_thread:174 started
Nov 24 18:30:14 kernel: ring_info_raw: 56
Nov 24 18:30:14 kernel: dc 53 3f 00 ac 64 3f 00 c0 66 3f 00 d4 68 3f 00
Nov 24 18:30:14 kernel: da 68 3f 00 00 00 00 00 00 00 00 00 00 00 00 00
Nov 24 18:30:14 kernel: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Nov 24 18:30:14 kernel: 00 00 00 00 0a 01 00 00
Nov 24 18:30:14 kernel: CUR_ETHERADDR : 6
Nov 24 18:30:14 kernel: f8 32 e4 53 1e bc
Nov 24 18:30:14 kernel: Dongle Host Driver, version 1.369.1 (r628771)
Nov 24 18:30:14 kernel: Compiled in drivers/net/wireless/bcmdhd on May 18 2016 at 16:42:53
Nov 24 18:30:14 kernel: Register interface [eth1] MAC: f8:32:e4:53:1e:bc
Nov 24 18:30:14 kernel: Empty flash at 0x038caa74 ends at 0x038cb000
Nov 24 18:30:15 RT-AC3100: start httpd
Nov 24 18:30:16 disk monitor: be idle
Nov 24 18:30:16 syslog: Generating SSL certificate...
Nov 24 18:30:17 syslog: module ledtrig-usbdev not found in modules.dep
Nov 24 18:30:17 syslog: module leds-usb not found in modules.dep
Nov 24 18:30:17 kernel: SCSI subsystem initialized
Nov 24 18:30:18 kernel: reset usb phy..
Nov 24 18:30:19 disk_monitor: Finish
Nov 24 18:30:20 disk monitor: be idle
