I have been using Merliln for a few years now and started with the AC-87U that is no longer supported but switched over to the AC3100 about a year ago....
So issue is:
SETUP:
I eliminated switch and cabled Direct to AC3100 from multiple desktops/servers and laptops to check as well. But with the changing firmware per above, as you can see it fluctuates on every device anyway so not cable or switch to begin with but wanted to be sure.
Any help would be greatly appreciated. I may downgrade further than 386.1_beta2 tomorrow to see where the problem started but with the security patches missing, that is not ideal
thanks
-MV.
So issue is:
- Upgraded to firmware RT-AC3100_386.2 final
- Was noticing a significant speed decrease on FIOS gigabit from 999-1100Mbps to around 250-300Mbps after upgrade
- Downgraded to each version in succession until I got to RT-AC3100_386.1_beta2 where speed returned to 999-1100
- However then if I enable time scheduling in parental controls (with NAT acceleration either on or off) the speed drops down to 250-300 similar to above.
- Once I turn off the time schedule, speed returns to the 999-1100Mbps again. And I can replicate this as will
- The newer firmwares above 386.1_beta2; even up to the brand new 386.2_beta1 released today all get the following results that are also fully replicatable:
- Time scheduling on: ~250 again
- Time scheduling off: ~300-350M (The Fios speed test even stated to “check the speed of your device” in orange as it knows there is an issue)
- So in order to get Gigabit speeds, I need to stay at 386.1_beta2 and leave time scheduling off. Very strange issue.
SETUP:
thanks
-MV.
