AC3200 will it support imesh?
xmatic
Basically asking if Imesh will be supported on this router as I've read it has almost the same hardware as an ASUS RT-AC68U. Or is there any firmware that currently supports imesh on this router?
ASUS AiMesh is a feature of ASUS firmware only. See the ASUS AiMesh page for a list of AiMesh-supported routers.
The RT-AC68U is an AC1900 build, so it may not be hardware equivalent to an AC3200 build. I doubt anyone besides ASUS can answer your question, and they will likely just refer you to their list of AiMesh-supported routers.
OE
