ac5300 download master
Paxsat
error download master
 sh /opt/S50downloadmaster.1 start
Feb 28 14:47:32 A.QoS: qos_count=0, qos_check=1
Feb 28 14:47:36 A.QoS: qos rule is less than 22
Feb 28 14:47:36 A.QoS: restart A.QoS because set_qos_conf / set_qos_on / setup rule fail
Feb 28 14:47:38 A.QoS: qos_count=1, qos_check=1
Feb 28 14:47:42 A.QoS: qos rule is less than 22
Feb 28 14:47:42 A.QoS: restart A.QoS because set_qos_conf / set_qos_on / setup rule fail
Feb 28 14:47:42 transmission-daemon[3220]: Transmission 2.92 (14714) started (session.c:768)
Feb 28 14:47:42 transmission-daemon[3220]: RPC Server Adding address to whitelist: 127.0.0.1 (rpc-server.c:1124)
Feb 28 14:47:42 transmission-daemon[3220]: RPC Server Adding address to whitelist: *.*.*.* (rpc-server.c:1124)
Feb 28 14:47:42 transmission-daemon[3220]: RPC Server Serving RPC and Web requests on port 127.0.0.1:9091/transmission/ (rpc-server.c:1334)
Feb 28 14:47:42 transmission-daemon[3220]: RPC Server Whitelist enabled (rpc-server.c:1338)
Feb 28 14:47:42 transmission-daemon[3220]: RPC Server Password required (rpc-server.c:1341)
Feb 28 14:47:42 transmission-daemon[3220]: Couldn't bind port 51413 on ::: Address already in use (Is another copy of Transmission already running?) (net.c:380)
Feb 28 14:47:42 transmission-daemon[3220]: UDP Failed to set receive buffer: requested 4194304, got 245760 (tr-udp.c:84)
Feb 28 14:47:42 transmission-daemon[3220]: UDP Please add the line "net.core.rmem_max = 4194304" to /etc/sysctl.conf (tr-udp.c:89)
Feb 28 14:47:42 transmission-daemon[3220]: UDP Failed to set send buffer: requested 1048576, got 245760 (tr-udp.c:95)
Feb 28 14:47:42 transmission-daemon[3220]: UDP Please add the line "net.core.wmem_max = 1048576" to /etc/sysctl.conf (tr-udp.c:100)
Feb 28 14:47:42 transmission-daemon[3220]: DHT Generating new id (tr-dht.c:311)
Feb 28 14:47:42 transmission-daemon[3220]: Using settings from "/tmp/mnt/Elements/Download2/config" (daemon.c:578)
Feb 28 14:47:42 transmission-daemon[3220]: Saved "/tmp/mnt/Elements/Download2/config/settings.json" (variant.c:1269)
Feb 28 14:47:42 transmission-daemon[3220]: transmission-daemon requiring authentication (daemon.c:604)
Feb 28 14:47:42 transmission-daemon[3220]: Port Forwarding (NAT-PMP) initnatpmp succeeded (0) (natpmp.c:70)
Feb 28 14:47:42 transmission-daemon[3220]: Port Forwarding (NAT-PMP) sendpublicaddressrequest succeeded (2) (natpmp.c:70)
Feb 28 14:47:43 A.QoS: qos_count=2, qos_check=1
remove asusware.arm dir and S50* into APPS
install again download master.. but not list in usb app
