AC5300 / FW: 380.62_1 - SSL Issues
Inch
Hi there,
Sorry if I'm possting in the wrong location.
However I'm trying to add my own fully signed SSL to my own router. Having followed this guide: https://www.rickygao.com.au/blog/how-to-upload-ssl-certificate-to-asus-router/
(sorry i hope im not breaking any rules posting an external link).
Upon following it and subsequently rebooting the device all .pem files key/cert's are reset to what seem to be defaults.
Is this a bug? Is it even supported anymore? Or is the above guide wrong in some way?
Thank you in advanced,
Inch
Thank you very much sir!
Sorry tried searching it didn't yeild any results I'll give this a test tonight.
Once again cheers!
NP, hope this will fix your issue. Saw it is already mentioned in the guide you used (step 5).
check what the current value is, it must be 1
nvram get https_crt_save
If you do a check for the content of the file, you must get the values for your own certificate you pasted before when following that guide
nvram get https_crt_file
Actually, you can't check the contents of https_crt_file, since what gets stored is actually a tar of the cert and key.
But, if you have been trying this a few times, things may have gotten out of sync. Before you execute the 'service restart_httpd' step in the guide, also check that https_crt_gen is 0.
Hey again,
OK, so I even tried using winSCP to connect via SCP to my router and manually change the .pem contents with the one of my private key and certificate.
Instead of doing a cat >path/cert etc
I then used SSH to 'set https_crt_save=1' and 'set https_cert_gen=0' and then used 'nvram commit', restarted the httpd service. It then took the certs they WERE showing as valid. Immediately after reboot they revered again even though i set cert_gen to 0 and (i believe) committed it to nvram.
Any tips - anything I'm doing blatantly wrong?
Thanks once again,
Re-checked to be sure, I re-did everything from scratch to confirm. Still wiping the pem files on reboot.
C RT-AC5300 showing devices as wired when wireless on clients list Asuswrt-Merlin 5
