I have USB 3.0 HDD (NTFS formatted) attached to router. In order to use it for backup purposes I have enabled Samba sharing. I'm using Win 8.1 (64bit)
1. When I enable guest login in Samba settings I am able to see HDD on my laptop (I can add whole HDD as network place or map network drive). If I disable guest login HDD as partition is not visible anymore, just single folders are visible, so I cant add whole partition as network place or network drive it asks for single folder only. What am I doing wrong? Is it possible at all to add whole partition without guest login?
2. Where can I found info about other settings under Samba settings (force browse master, simple name etc). Maybe I need to tweak those settings too?
3. Are there better HDD sharing methods for Windows other than Samba that works with usual backup software?
Thanx in advance
Thanx in advance
