[AC66/380.70] Query Against External DNS Servers Fails Only For Some Domains, And Only From Router
GokieKS
I'm having some really weird DNS issues that I can't figure out, which is driving me insane (and also with shame, seeing as how networking is part of my job). So I want to see if anyone can think of something that I'm missing.
The problem: DNS queries for many (but not all) sites, including seemingly all federal .gov ones*, are not working.
*: it seems the issue doesn't apply to ALL .gov domains - state domains (ca.gov, texas.gov, michigan.gov) seem to work fine, but all the federal ones I tried (state.gov, nasa.gov, treasury.gov, supremecourt.gov) don't.
Configuration: ASUS RT-AC66 running 380.70, configured to use the CloudFlare 1.1.1.1 / 1.0.0.1 as DNS servers. Clients do not have DNS servers specifically configured, thus they use the router.
Findings:
From my client desktop, DNS queries will fail when using the default DNS server (router), but if I run the query against the 1.1.1.1 DNS server, it works:
$ nslookup nasa.gov
Server: 192.168.1.1
Address: 192.168.1.1#53
** server can't find nasa.gov: SERVFAIL
$ nslookup nasa.gov 1.1.1.1
Server: 1.1.1.1
Address: 1.1.1.1#53
Non-authoritative answer:
Address: 52.0.14.116
Address: 23.22.39.120
So this would seem to indicate it's an issue with the router, likely the DNS forwarding. However, and this is the part that's weird, DNS queries made from the router against 1.1.1.1 also does not work:
RT-AC66R:/tmp/home/root# nslookup nasa.gov
Server:    127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
nslookup: can't resolve 'nasa.gov'
RT-AC66R:/tmp/home/root# nslookup nasa.gov 1.1.1.1
Server:    1.1.1.1
Address 1: 1.1.1.1 one.one.one.one
But DNS queries against some other domains appears to work just fine from the router:
RT-AC66R:/tmp/home/root# nslookup google.com
Server:    127.0.0.1
Address 1: 2607:f8b0:4000:80f::200e dfw25s16-in-x0e.1e100.net
Address 2: 216.58.194.142 dfw06s49-in-f142.1e100.net
kai@RT-AC66R:/tmp/home/root# nslookup google.com 1.1.1.1
Server:    1.1.1.1
And this issue is not specific to Cloudflare's DNS servers. I've tried using Google's 8.8.8.8 instead, and the results are exactly the same
Working from client:
$ nslookup nasa.gov 8.8.8.8
Server: 8.8.8.8
Address: 8.8.8.8#53
Not working from router for nasa.gov:
RT-AC66R:/tmp/home/root# nslookup nasa.gov 8.8.8.8
Server:    8.8.8.8
Address 1: 8.8.8.8 google-public-dns-a.google.com
But working from router for google.com:
RT-AC66R:/tmp/home/root# nslookup google.com 8.8.8.8
Server:    8.8.8.8
Address 1: 2607:f8b0:4000:80c::200e dfw06s48-in-x0e.1e100.net
Address 2: 172.217.6.174 dfw25s17-in-f174.1e100.net
So, at this point I'm pretty stumped. I've tried everything I can think of (restarting dnsmasq service, restarting the router, restarting the modem), to no avail. If anyone has any ideas or can think of something I might be missing, I would love to know.
If you have DNSSEC enabled try disabling it.
Go by process of elimination? My last ditch troubleshooting method is to backup settings and then factory reset router and step by step go through setup to see when the problems begin.
B RT-AX86U Merlin Firmware:3004.388.11 IPTV VLAN Query Asuswrt-Merlin 2
