AC66U and problem with pings from WiFi client
Bieniu
Hi
I have AC66U with AsusWrt-Merlin 380.58 (with 380.57 there is the same issue). When I ping some server from WiFi client (laptop with Windows 10) I have a lot losts. From computer that is wired connected there is no lost.
For example pings from my laptop:
Reply from 8.8.8.8: bytes=32 time=35ms TTL=48
Reply from 8.8.8.8: bytes=32 time=31ms TTL=48
Reply from 8.8.8.8: bytes=32 time=32ms TTL=48
Reply from 8.8.8.8: bytes=32 time=34ms TTL=48
Reply from 8.8.8.8: bytes=32 time=30ms TTL=48
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 8.8.8.8: bytes=32 time=28ms TTL=48
Reply from 8.8.8.8: bytes=32 time=37ms TTL=48
Reply from 8.8.8.8: bytes=32 time=29ms TTL=48
Request timed out.
Reply from 8.8.8.8: bytes=32 time=67ms TTL=48
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 8.8.8.8: bytes=32 time=155ms TTL=48
Reply from 8.8.8.8: bytes=32 time=42ms TTL=48
Reply from 8.8.8.8: bytes=32 time=33ms TTL=48
Request timed out.
Request timed out.
Reply from 8.8.8.8: bytes=32 time=36ms TTL=48
Request timed out.
Request timed out.
Reply from 8.8.8.8: bytes=32 time=199ms TTL=48
Reply from 8.8.8.8: bytes=32 time=2093ms TTL=48
Reply from 8.8.8.8: bytes=32 time=51ms TTL=48
Request timed out.
Request timed out.
Request timed out.
Reply from 8.8.8.8: bytes=32 time=43ms TTL=48
Request timed out.
Reply from 8.8.8.8: bytes=32 time=27ms TTL=48
I restore router to factory default, try 2,4 and 5 GHz, try another WiFi adapter, change SSID and nothing helps. WiFi settings is Merlin default. Any solution for that problem?
