Zolt
So I finally found my issue I've been facing for a little while now.
I have 2 RT-AC66U B1 routers set in AIMesh mode.
I was having all kind of disconnect, and it seems it was due to my main unit - it's also the oldest of the two.
I've been pushing this for too long now, but today, I decided to swap the units : the AIMesh node became the Main router.
The older one, I tried to reset, and started having all kind of issues. I ended up using the Firmware Restoration tool from ASUS, but that failed - every time I tried, it failled at ~40% of uploading the FW. Good assumption that my disconnects were due to this unit...
The house is large, and I really want to have an AIMesh setup or something equivalent.
What do you suggest for an affordable AIMesh compatible router that I could use with my existing unit?
Possibly, the RT-AC66U could go back to being the AIMesh node and the new router the main if it's more advanced.
...or are other brand compatible with AIMesh maybe?
Worst comes to worst, I'll just get another of these units - I really like them and the main one has been running for a couple years and just started having issues - it also survived 2 moves
Open for suggestions - thanks for your input!
Cheers!
Cheers!
