AC66U - guide for setting up External logging
lurc
Hi.
I am looking to set up external logging for the AC66U. The idea is to ingest them in splunk. However I can not find a way to set up external logging in the web GUI.
Can anybody please help me with a guide on setting up external logging?
Hi.
Administration -> System. Enter the IP of the remote syslog server on that page.
Thanks. I finally got a connection. Any way to route the traffic logs as well?
Enable firewall logging on the Firewall page. Logging will go to syslog.
Logging questions.
I need to log the entries listed under the "Connections" tab in the "System Log" page of the router configuration. How can I do this? I need the internal NATted address specifically so I can track down a particular system.
The reason I need this is that I have a number of systems on my network, some wireless and some wired. I can see dangerous traffic outbound on my external NIDS, but even if I turn the firewall logs on for "all" traffic I can't tell which internal system sent the traffic.
Thanks in advance!
JS
Thanks in advance!
JS
These aren't a realtime display you can monitor or a logfile getting dumped - it's a list generated by running the netstat-nat command. You can manually run the same command over Telnet.
