Hi!
Been reading for a while but first time I've had the need to post, this problem seems to be out of my hands! So any help would be much appreciated!
The situation is i have a Asus AC66u router, and for the first time recently have attempted to transfer files from one computer to another via my network. The average transfer rate is around 4-10Mbps, which on average is lower than my actual download speeds. Both computers are hooked up wirelessly using AC adapters which boast speeds of ~600Mbps for one and ~850Mbps for the other. Both are running Samsung SSD Pro's so i don't believe that that is the bottle neck in the system. Have also tried hooking one up to the router via a CAT 5e cable with no help.
One computer is windows 8, while the other is windows 7. The firmware on the AC66U is 376.47 Merlin Build.
The SSID for both my 2.4 and 5GHz are different. No one else in my area has a 5GHz connection, and the settings for the 5GHz connection are as follows.
Wireless Mode Auto
Channel bandwidth 20/40/80 Mhz
Control Channel Auto
Extension Channel Auto
Any help would be great as this has been killing me slowly! If i missed any information that is needed let me know!
Thanks a ton
Wireless Mode Auto
Thanks a ton
