nyfirefly11
EDIT: I figured out the power/connection issue - it's now up and running. But the system clock is 6 months behind. Any ideas?
Original post:
I already had 378.55 installed on my AC-66U, and it was working great (with the exception of the system time being 45 days behind). I was hoping 380.57 would help, so I performed the upgrade - it uploaded, flashed and told me to manually reboot.
I pulled the power out for 30+ seconds, plugged it backed in, and I couldn't access the router via the https static IP/port I set up.
Any ideas? Should I do a hard reset?
Also, once I get it back up (assuming I can), and the time still isn't right, any ideas on what to do about that? I've tried multiple NTP servers, but it doesn't seem to ping them.
P.S. My AC66U is acting as a wifi AP plugged into my N66U (which has 378.55 and a correct system time).
Original post:
