Hello everyone, I apologize if I come shorthanded with information, but as the title states my AC66U has never, ever had a stable vpn connection, it sometimes works, for a while, then dies, the DNS has a tendency to die with it.
3.0.0.4.376.49_5 is my current firmware, I have been updating and updating every now and then, hoping that NOW its fixed and so on, originally this was my issue in the very beginning after I bought it, to try to fix the buggy VPN with merlins firmware.
I am using windows 7 computers with the buildt in VPN and have setup standard workplace connection (VPN connection)
Here I looked in the system log and can see that the connection dropped, I just do not know why, everything in my router is pretty much standard, exept for a few routes, including the "internal vpn fix loop" route aswell:
Feb 23 09:13:53 dnsmasq-dhcp[425]: DHCPREQUEST(br0) 192.168.1.63 AB:CD:EF:GH:12:34
Feb 23 09:13:53 dnsmasq-dhcp[425]: DHCPACK(br0) 192.168.1.63 AB:CD:EF:GH:12:34 datarom
Feb 23 09:50:25 pptpd[10212]: CTRL: Client xxx.xxx.xxx.xxx control connection started
Feb 23 09:50:25 pptpd[10212]: CTRL: Starting call (launching pppd, opening GRE)
Feb 23 09:50:25 pptp[10213]: Plugin pptp.so loaded.
Feb 23 09:50:25 pptp[10213]: PPTP plugin version 0.8.5 compiled for pppd-2.4.7, linux-2.6.22.19
Feb 23 09:50:25 pptp[10213]: pppd 2.4.7 started by admin, uid 0
Feb 23 09:50:25 pptp[10213]: Using interface ppp10
Feb 23 09:50:25 pptp[10213]: Connect: ppp10 <--> pptp (xxx.xxx.xxx.xxx)
Feb 23 09:50:26 pptpd[10212]: CTRL: Ignored a SET LINK INFO packet with real ACCMs!
Feb 23 09:50:26 pptp[10213]: MPPE 128-bit stateless compression enabled
Feb 23 09:50:26 pptp[10213]: Cannot determine ethernet address for proxy ARP
Feb 23 09:50:26 pptp[10213]: local IP address 192.168.1.1
Feb 23 09:50:26 pptp[10213]: remote IP address 192.168.10.2
Feb 23 10:25:52 pptpd[10303]: CTRL: Client xxx.xxx.xxx.xxx control connection started
Feb 23 10:25:52 pptpd[10303]: CTRL: Starting call (launching pppd, opening GRE)
Feb 23 10:25:52 pptp[10304]: Plugin pptp.so loaded.
Feb 23 10:25:52 pptp[10304]: PPTP plugin version 0.8.5 compiled for pppd-2.4.7, linux-2.6.22.19
Feb 23 10:25:52 pptp[10304]: pppd 2.4.7 started by admin, uid 0
Feb 23 10:25:52 pptp[10304]: Couldn't allocate PPP unit 10 as it is already in use
Feb 23 10:25:52 pptp[10304]: Using interface ppp11
Feb 23 10:25:52 pptp[10304]: Connect: ppp11 <--> pptp (xxx.xxx.xxx.xxx)
Feb 23 10:25:55 pptpd[10303]: CTRL: Ignored a SET LINK INFO packet with real ACCMs!
Feb 23 10:25:56 pptp[10304]: MPPE 128-bit stateless compression enabled
Feb 23 10:25:56 pptp[10304]: Cannot determine ethernet address for proxy ARP
Feb 23 10:25:56 pptp[10304]: local IP address 192.168.1.1
Feb 23 10:25:56 pptp[10304]: remote IP address 192.168.10.3
Feb 23 10:43:16 pptpd[10303]: CTRL: EOF or bad error reading ctrl packet length.
Feb 23 10:43:16 pptpd[10303]: CTRL: couldn't read packet header (exit)
Feb 23 10:43:16 pptpd[10303]: CTRL: CTRL read failed
Feb 23 10:43:16 pptpd[10303]: CTRL: Client pppd TERM sending
Feb 23 10:43:16 pptpd[10303]: CTRL: Client pppd finish wait
Feb 23 10:43:16 pptp[10304]: Terminating on signal 15
Feb 23 10:43:16 pptp[10304]: Connect time 17.4 minutes.
Feb 23 10:43:16 pptp[10304]: Sent 14416931 bytes, received 1227041 bytes.
Feb 23 10:43:16 pptp[10304]: MPPE disabled
Feb 23 10:43:16 pptp[10304]: Connection terminated.
Feb 23 10:43:16 pptp[10304]: Exit.
Feb 23 10:43:16 pptpd[10303]: CTRL: Client xxx.xxx.xxx.xxx control connection finished
Feb 23 10:43:18 bcrelay[378]: ignored ENXIO from sendto(), a network interface went down?
