I have an AC66U_B1 and flashed the RT-AC68U_386.4_0.zip firmware after seeing the notification in router interface for an update. After the flash finished and rebooted only that LAN and Power LED would be on and was totally unresponsive via LAN. Took me forever to get recovery mode activated so I could recover. If anyone else has the issue I did, set a static IP (192.168.1.3/24) on the machine attempting to recover the router, unplug unit, press and hold WPS button and insert power plug, when power light started flashing I tapped the reset button, after tapping the reset button I started receiving ping responses and opened http connection to 192.168.1.1 and was able to load the previous firmware RT-AC68U_386.3_2.zip. Unit is back up and running, though it shows in web interface that I am on firmware 386.4.
Before rolling back I attempted flashing .4 and after reboot it acted same way. Had to use 3_2 to recover. Router interface shows it's running .4 though.
Not sure what is going on but wanted to put this out there so maybe whatever the issue is might get resolved.
Blessings
Blessings
