Hi RMerlin,
I have an AC68R H/W Rev A1 which I upgraded from Merlin 55 to latest Merlin 380.59. The weird thing is that under HW acceleration, it shows both CTF+FA as enabled (as below), after the upgrade. How is this possible, since I understood that A1 lacks the hardware to support Flow Acceleration (I read an earlier post by you that only C1 onwards should have this feature). Is this a potential bug in 380.59? If not, is there a method at Unix prompt level (perhaps check for the presence of a loaded kernel module?) that I can test to figure out if it is GUI bug or actual Flow Accelaration? Default CPU speed is 800Mhz
Under Tools->Sysinfo
HW acceleration Enabled (CTF + FA)
CPU Model ARMv7 Processor rev 0 (v7l) - (Cores: 2)
Under Lan->Switch Control
NAT Acceleration CTF (Cut Through Forwarding) and FA (Flow Acceleration) accelerator are enabled.
