Hello,
I run nginx server (used for small local web page, low traffic) and I noticed recently it wasn't running. I SSH to the router, logged in but was not getting the prompt - just blank cursor and not responding to any commands. Now this happens often so I logged into web page, in attempt to reboot, but before I clicked reboot I clicked on the AI Network Protection which never loaded and at this point the Web UI stopped responding - nothing would load. This also happens often so I have a weekly reboot schedule. I have a external controller SSH-ing to the router multiple times a day so I contributed these glitches to that (been running like that for a year).
My only option left was to power cycle. After boot, nginx complained of missing libmxm12 package. I tried removing, re-installing, force re-installing with opkg but getting following errors:
Then I went to the first directory and:Installing libxml2 (2.9.10-3) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libxml2_2.9.10-3_armv7-2.6.ipk
Collected errors:
* wfopen: //opt/lib/opkg/info/libxml2.control: Input/output error.
* extract_archive: Cannot create symlink from ./opt/lib/libxml2.so.2 to 'libxml2.so.2.9.10': Input/output error.
* wfopen: /opt/lib/libxml2.so.2.9.10: Input/output error.
* pkg_write_filelist: Failed to open //opt/lib/opkg/info/libxml2.list: Input/output error.
* opkg_install_pkg: Failed to extract data files for libxml2. Package debris may remain!
* opkg_install_cmd: Cannot install package libxml2.
Then I did dmesg and got:# ls libx*
ls: libxml2.control: Input/output error
ls: libxml2.list: Input/output error
So it seems like I have corrupted file system or possibly failing nvram. What would you say I should attempt to next? Getting above my pay grade so asking for advice before I make it worse.EXT4-fs error (device sda1): ext4_iget:5126: inode #262369: comm ls: bad extended attribute block 8396864
EXT4-fs error (device sda1): ext4_ext_check_inode:454: inode #262372: comm ls: bad header/extent: invalid magic - magic f10a, entries 1, max 4(0), depth 512(512)
