Looking for assistance from the community. I have both the AC66R and AC68R, both running 374.42_2. The AC66R traffic monitor functions as expected, no issues, no problems. I am seeing odd behavior from the AC68R.....The AC68R is the main and only router on the network connected to a Comcast SB6141 modem. Two of the LAN ports on the 68R are connected to 8 ports dumb switches, while the other two ports have computers connected to them directly. The traffic monitor reports all wireless activity correctly within the "Internet, "2.4GHz" and "5GHz" tabs......the issue exists on the wired side....any wired connection whether directly connected to the router or going through the dumb switches shows absolutely no activity on the "Wired" tab in the traffic monitor (real-time) and on the "Internet" tab correctly shows incoming bandwidth but for outgoing bandwidth i see this behavior: outbound bandwidth = outbound bandwidth + inbound bandwidth..... This behavior carries over to all the other traffic monitor reports. Hence for any 24-hour period, or daily reports my outbound traffic is always greater than the inbound traffic. This is very evident when streaming video. If I stream 10GB of video for example, the outbound traffic reports 12GB.
I have seen this behavior on at least the past 3 iterations of Merlin's and ASUS' firmware when i started noticing this behavior. I have tried numerous factory resets with no help...However if I swap the 68R for the 66R all traffic behavior functions as expected.
Am I just insane or is there something wrong going on here? Any helpful input will be appreciated.
