Hi all,
I have an old Mac Mini that I use as the kids' Plex server. It's running 10.8.5 and has been trouble free for years as far as I remember.
I recently noticed a CPU spike on my AC68U and 'top' pointed to the dnsmasq process. I had a look at the log file (also running AB-Solution 3.0) and noticed the following entries:
Feb 12 17:26:36 dnsmasq[11125]: query[PTR] b._dns-sd._udp.0.1.168.192.in-addr.arpa from 192.168.1.11
Feb 12 17:26:37 dnsmasq[11125]: forwarded b._dns-sd._udp.0.1.168.192.in-addr.arpa to 8.8.8.8
Feb 12 17:26:37 dnsmasq[11125]: query[PTR] r._dns-sd._udp.0.1.168.192.in-addr.arpa from 192.168.1.11
Feb 12 17:26:37 dnsmasq[11125]: forwarded r._dns-sd._udp.0.1.168.192.in-addr.arpa to 8.8.8.8
Feb 12 17:26:37 dnsmasq[11125]: query[PTR] db._dns-sd._udp.0.1.168.192.in-addr.arpa from 192.168.1.11
Feb 12 17:26:37 dnsmasq[11125]: forwarded db._dns-sd._udp.0.1.168.192.in-addr.arpa to 8.8.8.8
Feb 12 17:26:37 dnsmasq[11125]: query[PTR] lb._dns-sd._udp.0.1.168.192.in-addr.arpa from 192.168.1.11
Feb 12 17:26:37 dnsmasq[11125]: forwarded lb._dns-sd._udp.0.1.168.192.in-addr.arpa to 8.8.8.8
They (or those much like them) were repeated thousands of times, hundreds per second and all coming from my Mac Mini. I understand these are reverse DNS lookups.
A reboot of the Mac made the problem go away but it has since reoccured. My searches seem to indicate (vague hints only) that it could be a DNS issue.
Has anyone come across something similar or have any suggestions?
