My AC68u worked fine for years but, one day, the web interface stopped responding entirely. Worked with Asus support and they suggested a factory reset. While the factory reset appears to work, the moment the device is configured in any mode the web interface will go unresponsive again. While in this state the device still serves up connections, IP addresses, and all though it is unmanageable.
Due to this, I replace the AC68u with an Aruba AP11D. A nice feature of the Aruba is that networks can be created and then have features defined. For example, I can create a single wirless network (name: Network) and then enable Network to transmit either 2.4 or 5GHz signals, automatically determined by the AP11D. I could also create Network2 and Network5, each one carrying just one signal band if I wanted. Understanding this flexibility is key for the actual question....
Can the AC68u be configured in a repeater mode that will use the same SSID as the original signal so as to create a mesh network? A single network that will seamlessly, without dropping connection, handoff from the Aruba to the AC68u?
I had written this earlier with just the previous question but now have an additional bad behavior to mention as there might be another problem here...
Just to get things working I had setup the repeater mode with an EXT. So Network_EXT offered by AC68u and Network offered by AP11D. Even though devices (smart bulbs and switches) that were previously working have an even stronger signal from the AC68u they are dropping connection and going offline at random. Sometimes an on/off request will take up to a minute for no apparent reason.
