I turned on IPv6 then a PC hard wired to the router lost internet connection. The Network and Sharing center indicates the PC is connected to LAN. Any device connected via WiFi stays connected to the Internet.
If I attempt to access 192.168.1.1 from the PC wired to the router returned the following message. What did I do wrong?
The message is here.
Edit: After the attempted config change(turning on IPv6) the PC(hard wired to the router) used to do so is no longer connected to the home network but to Unidentified network(Public network). test-ipv6.com showed that IPv6 is turned on.
