sandiegoboy
Can anybody comment on the effectiveness of using:
1. High Gain Antenna
2. A cable extension/base to locate the antenna a bit away from router and possibly higher
3. Both #1/#2 together
I have read some complains that high gain antennas dont really work. In another forum somebody indicated that using the cable extension and setting the (original) antennas a bit further apart had a positive impact
