AC68U Issues with Chromecast Audio?
Infamous4Chan
Does anyone else have an AC68U working with a Chromecast Audio? Mine has never worked properly since I got the router, and it's definitely the router since when I was troubleshooting and went back to my old router, it worked perfectly.
My issue is primarily with Spotify but this occurs with other apps, from an LG G4; when I skip a couple of songs quickly, the next song to play doesn't play, and nothing works until I disconnect and reconnect to the router. Basically skipping a couple of songs quickly in succession seems to jam something up.
Running stock firmware, this happens on all versions of the firmware so far, and I've contacted Google and Asus but their suggestions did not help.
Any ideas or experience?
Cheers
