AC68U - One of the CPU cores always hitting 100% when downloading
IceTea
Like it says on the title, core 1 at 100% usage when downloading.
Ran 'top' on the router, and the culprit is [ksoftirqd/0].
HW Acceleration is enabled. All the extra features are disabled(QoS, AI Protection, etc.)
Running the latest Merlin Firmware (386.3_2)
My WAN is PPPoE
LAN cable is CAT6
CPU Model BCM470x - Cortex A7 ARMv7 revision 0 - Rev. c0 (Cores: 2)
CPU Frequency 1000 MHz
CPU Load Average (1, 5, 15 mins) 0.12, 0.16, 0.19
CPU Temp ~60C
I have tried doing a Nuclear Reset as set out here https://www.snbforums.com/threads/major-issues-w-rt-ac86u.56342/page-4#post-495710
I don't even have any addons or amtm installed after the reset, but I still get the same behaviour.
Does anyone have any insight?
My main issue with this is that I got 1gbps fibre recently, and I seem to be bottlenecked at ~750mbps, whereas other people I know with the same router, gets about 920mbps... <Cries in first-word problems, even though I am in a third-word country>
If you're not downloading to a USB attached drive, M&M time.
From what I've read in these forums it appears to be a hardware limitation of the RT-AC68U when using PPoE connections. Link.
Maybe the hardware is done?
I hope not too.
