Digitald00d
My first post so go easy.
My setup:
AC68U setup to my ISP as a normal router, call it RTR.
AC68P setup as a repeater, call it REP.
Merlin version 384.5
RTR is in an outside building and REP is inside house. About 60ft apart, glass windows in between. When setting up, I have the two talking via the 5G network as it appeared much faster. I have two wireless SSID's setup on both the RTR and REP. I CAN change the wireless channels on the RTR but CANNOT change the wireless channels on the REP.
What I really expected was the wireless SSID's and channels setup on the RTR to be extended to the REP. The way it ended up is listed below.
RTR 5G REP 5G (mode: repeater)
k33p0ut5R k33p0ut5
149/80 149/80
RTR 2G REP 2G (mode: AP)
k33p0utR k33p0ut
11u 3
I thought the 2G would get extended the same as the 5G did, even though I have 4 separate SSID being used. When I connect to the 2G in the house, sometimes it's very hesitant. Sometimes I have to disconnect and re-connect to the 2G to get it client going. I suspect there is interference on the 2G. That is why I wanted to extend the 2G channel 11 from the RTR. The only way to see the REP channel is looking at the wireless log.
I've also attached a couple screenshots. Ask away, I'll answer best I can. Any guidance is much appreciated. Thanks in advance!
My setup:
k33p0ut5R k33p0ut5
149/80 149/80
k33p0utR k33p0ut
11u 3
