With the vodafone router I get 900+ Mbps downstream.
...But if I use my AC68U in its place and doing a speed test from the router itself I get only 1/3rd of that (slightly more than that upstream consistently for some reason). QoS is disabled - I even checked it was disabled in NVRAM.
I'm using PPoE to authenticate. Cityfiber needs you to have VLAN 911 set which I did through the IPTV page. Are there any other settings that could cause this?
The CPU seems to max out during the speedtest - I overclocked the CPU but the result stays *exactly* the same.
Is this model just not gigabit capable?
I even daisy-chained them together.....
fiber <-> vodafone <-> ac68u
and ran the speed test again with the same result making me think it's just not powerful enough.
