tarzan2000
Good afternoon friends.
Tell me in my situation.
All local wired devices are connected to the D'link DGS-1005D switch. Switch1(OLED, AppleTV4K,STB,AV Yamaha, AcerRL80) is connected by cable to the same switch2 (NAS, VoIP DECT) located at the router. Next, the cable from the second switch2 goes to the AC86U (384.16). Wi-Fi clients are connected directly to the router through the air.
In my network configuration (at home) a very strange and incomprehensible problem arises with AC86u (384.16) when OLED Panasonic GZR1000 is connected to it via Wi-fi 2.4/5Hz.
At a router LAN \ wi-fi routing in a segment of a local network completely falls off. At the same time, routing in WAN works fine (there is an Internet). Those, I lose access to all local resources on the network (NAS, smb share and web access to STB ipTV box)
Turn off the TV (connected via Wifi) - no problem.
As soon as I connect the GZR1000 with a cable to the same router - no problem.
I began to understand the situation whether the router or the panasonic network interface is to blame.
I changed the router to Asus N66u - the same thing.
The Panasononic GZR 2019 series has a wifi module from Askey Computer Corp - which is a subsidiary of Asustek
Somehow on the router can i find or understand what could be the reason for this behavior of the local network and devices in it?
