AC86U - Internet Disconnected if JFFS Script on, see log
wizin
Last I installed spdMerlin - and then updated to 10_2
Now, I boot and get this - and Network is disconnected, as soon I turn JFFS Script off, all is OK
Apr 14 16:37:11 rc_service: watchdog 803:notify_rc start_dnsmasq
Apr 14 16:37:11 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf ) - max timeout = 120s
Apr 14 16:37:11 Diversion: auto-added IPv6 entries to blocking list(s) and blacklist, this might have taken some time, from /jffs/scripts/dnsmasq.postconf
Apr 14 16:37:11 Diversion: restarted Dnsmasq to apply settings, from /jffs/scripts/dnsmasq.postconf
Apr 14 16:37:11 dnsmasq[4627]: cannot open log /opt/var/log/dnsmasq.log: Read-only file system
Apr 14 16:37:11 dnsmasq[4627]: FAILED to start up
Apr 14 16:37:41 rc_service: watchdog 803:notify_rc start_dnsmasq
Apr 14 16:37:41 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf ) - max timeout = 120s
Apr 14 16:37:41 Diversion: auto-added IPv6 entries to blocking list(s) and blacklist, this might have taken some time, from /jffs/scripts/dnsmasq.postconf
Apr 14 16:37:41 Diversion: restarted Dnsmasq to apply settings, from /jffs/scripts/dnsmasq.postconf
Apr 14 16:37:41 dnsmasq[4759]: cannot open log /opt/var/log/dnsmasq.log: Read-only file system
Apr 14 16:37:41 dnsmasq[4759]: FAILED to start up
Apr 14 16:38:11 rc_service: watchdog 803:notify_rc start_dnsmasq
Apr 14 16:38:11 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf ) - max timeout = 120s
Apr 14 16:38:11 Diversion: auto-added IPv6 entries to blocking list(s) and blacklist, this might have taken some time, from /jffs/scripts/dnsmasq.postconf
Apr 14 16:38:11 Diversion: restarted Dnsmasq to apply settings, from /jffs/scripts/dnsmasq.postconf
Apr 14 16:38:11 dnsmasq[4940]: cannot open log /opt/var/log/dnsmasq.log: Read-only file system
Apr 14 16:38:11 dnsmasq[4940]: FAILED to start up
Is your USB drive mounted? Since it thinks /opt/var/log is read-only, it would seem something is wrong with your usb or the soft link from /tmp/opt is broken.
Run df in ssh to see what’s there.
Hello
Issue remains after removing and readding USB
Apr 15 19:23:37 pixelserv-tls[28451]: pixelserv-tls 2.2.1 (compiled: Mar 20 2019 07:45:07 flags: tfo tls1_3) options: <none>
Apr 15 19:23:37 reg828: Started pixelserv-tls from /opt/bin/diversion.
Apr 15 19:23:37 pixelserv-tls[28451]: Listening on :*:443
Apr 15 19:23:37 pixelserv-tls[28451]: Abort: Address already in use - :*:80
Apr 15 19:23:47 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:23:52 rc_service: service 28658:notify_rc restart_dnsmasq
Apr 15 19:23:52 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf ) - max timeout = 120s
Apr 15 19:23:52 Diversion: auto-added IPv6 entries to blocking list(s) and blacklist, this might have taken some time, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:23:53 Diversion: restarted Dnsmasq to apply settings, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:23:53 dnsmasq[28897]: cannot open log /opt/var/log/dnsmasq.log: Read-only file system
Apr 15 19:23:53 dnsmasq[28897]: FAILED to start up
Apr 15 19:24:02 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:24:06 rc_service: watchdog 802:notify_rc start_dnsmasq
Apr 15 19:24:06 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf ) - max timeout = 120s
Apr 15 19:24:06 Diversion: auto-added IPv6 entries to blocking list(s) and blacklist, this might have taken some time, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:24:06 Diversion: restarted Dnsmasq to apply settings, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:24:06 dnsmasq[29035]: cannot open log /opt/var/log/dnsmasq.log: Read-only file system
Apr 15 19:24:06 dnsmasq[29035]: FAILED to start up
Apr 15 19:24:16 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:24:32 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:24:36 rc_service: watchdog 802:notify_rc start_dnsmasq
Apr 15 19:24:36 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf ) - max timeout = 120s
Apr 15 19:24:36 Diversion: auto-added IPv6 entries to blocking list(s) and blacklist, this might have taken some time, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:24:36 Diversion: restarted Dnsmasq to apply settings, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:24:36 dnsmasq[29171]: cannot open log /opt/var/log/dnsmasq.log: Read-only file system
Apr 15 19:24:36 dnsmasq[29171]: FAILED to start up
Apr 15 19:24:46 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:25:01 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:25:06 rc_service: watchdog 802:notify_rc start_dnsmasq
Apr 15 19:25:06 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf ) - max timeout = 120s
Apr 15 19:25:06 Diversion: auto-added IPv6 entries to blocking list(s) and blacklist, this might have taken some time, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:25:06 Diversion: restarted Dnsmasq to apply settings, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:25:06 dnsmasq[29290]: cannot open log /opt/var/log/dnsmasq.log: Read-only file system
Apr 15 19:25:06 dnsmasq[29290]: FAILED to start up
Apr 15 19:25:17 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:25:31 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:25:36 rc_service: watchdog 802:notify_rc start_dnsmasq
Apr 15 19:25:36 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf ) - max timeout = 120s
Apr 15 19:25:36 Diversion: auto-added IPv6 entries to blocking list(s) and blacklist, this might have taken some time, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:25:36 Diversion: restarted Dnsmasq to apply settings, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:25:36 dnsmasq[29449]: cannot open log /opt/var/log/dnsmasq.log: Read-only file system
Apr 15 19:25:36 dnsmasq[29449]: FAILED to start up
Apr 15 19:25:46 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:26:02 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:26:06 rc_service: watchdog 802:notify_rc start_dnsmasq
Apr 15 19:26:06 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf ) - max timeout = 120s
Apr 15 19:26:06 Diversion: auto-added IPv6 entries to blocking list(s) and blacklist, this might have taken some time, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:26:06 Diversion: restarted Dnsmasq to apply settings, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:26:06 dnsmasq[29572]: cannot open log /opt/var/log/dnsmasq.log: Read-only file system
Apr 15 19:26:06 dnsmasq[29572]: FAILED to start up
Apr 15 19:26:16 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:26:31 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:26:36 rc_service: watchdog 802:notify_rc start_dnsmasq
Apr 15 19:26:36 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf ) - max timeout = 120s
Apr 15 19:26:36 Diversion: auto-added IPv6 entries to blocking list(s) and blacklist, this might have taken some time, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:26:36 Diversion: restarted Dnsmasq to apply settings, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:26:36 dnsmasq[29690]: cannot open log /opt/var/log/dnsmasq.log: Read-only file system
Apr 15 19:26:36 dnsmasq[29690]: FAILED to start up
Apr 15 19:26:46 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:27:01 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:27:06 rc_service: watchdog 802:notify_rc start_dnsmasq
Apr 15 19:27:06 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf ) - max timeout = 120s
Apr 15 19:27:06 Diversion: auto-added IPv6 entries to blocking list(s) and blacklist, this might have taken some time, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:27:06 Diversion: restarted Dnsmasq to apply settings, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:27:06 dnsmasq[29810]: cannot open log /opt/var/log/dnsmasq.log: Read-only file system
Apr 15 19:27:06 dnsmasq[29810]: FAILED to start up
Apr 15 19:27:16 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:27:31 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:27:36 rc_service: watchdog 802:notify_rc start_dnsmasq
Apr 15 19:27:36 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf ) - max timeout = 120s
Apr 15 19:27:36 Diversion: auto-added IPv6 entries to blocking list(s) and blacklist, this might have taken some time, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:27:36 Diversion: restarted Dnsmasq to apply settings, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:27:36 dnsmasq[29934]: cannot open log /opt/var/log/dnsmasq.log: Read-only file system
Apr 15 19:27:36 dnsmasq[29934]: FAILED to start up
Apr 15 19:27:46 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:28:02 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:28:06 rc_service: watchdog 802:notify_rc start_dnsmasq
Apr 15 19:28:06 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf ) - max timeout = 120s
Apr 15 19:28:06 Diversion: auto-added IPv6 entries to blocking list(s) and blacklist, this might have taken some time, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:28:06 Diversion: restarted Dnsmasq to apply settings, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:28:06 dnsmasq[30053]: cannot open log /opt/var/log/dnsmasq.log: Read-only file system
Apr 15 19:28:06 dnsmasq[30053]: FAILED to start up
Apr 15 19:28:17 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:28:31 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Apr 15 19:28:36 rc_service: watchdog 802:notify_rc start_dnsmasq
Apr 15 19:28:36 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf ) - max timeout = 120s
Apr 15 19:28:36 Diversion: auto-added IPv6 entries to blocking list(s) and blacklist, this might have taken some time, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:28:36 Diversion: restarted Dnsmasq to apply settings, from /jffs/scripts/dnsmasq.postconf
Apr 15 19:28:36 dnsmasq[30180]: cannot open log /opt/var/log/dnsmasq.log: Read-only file system
Apr 15 19:28:36 dnsmasq[30180]: FAILED to start up
Apr 15 19:28:46 WLCEVENTD: eth5: Assoc 7C:ED:8D:9E:08:95
Use the amtm disk check, your USB device is corrupted.
Or your USB device runs out of space since you enabled IPv6 and this doubles the size of the blocking file(s) with the added entries.
